PVTrans OFS is searching for Lead Mechanical Technician
PVTrans Oilfield Services is searching for Lead Mechanical Technician to join our team for Sao Vang – Dai Nguyet Project.
Specific Accountabilities:
  • Able to carry out planned mechanical maintenance in accordance with the requirements of the planned maintenance system.
  • Experienced in undertaking fault finding, installation, isolation and re-instatement on mechanical systems and equipment – both rotating and static.
  • Communication skills and the ability to present complex technical issues in a clear and concise manner.
  • Safeguarding the reliability, availability and operational condition of static and rotating mechanical equipment.
  • Extensive knowledge in diesel generators, gas turbines, hydraulics, and gas compression trains, compressors, pumps, cranes, HVAC and other rotating equipment.
  • Knowledgeable and experienced in static mechanical equipment including pressure vessels, valves, heat ex-changers, and other process equipment of offshore topside.
  • Ensure underlying causes of failures are understood and appropriate action taken to avoid repeat failures.
  • Management processes, including the raising of relevant work permits.
  • Lead, supervise on site and actively support Mechanical Technicians, Contractors and Vendors to ensure work is executed in a safe, efficient and professional manner.
  • Highlight defects in practices, procedures, equipment and tools to the attention of relevant staff.
  • Material requisition raise including spare part/tools ordering and replenishment.
  • Ensure comprehensive records and logs are maintained and effective handovers are carried out at shift and crew change.
  • Emergency response role
Minimum Competencies:
  • Mechanical Technologist Certificate in Mechanics or equivalent.
  • 5 years related experience in a marine or Topsides maintenance environment (offshore oil and gas operations would be an asset) with 1-3 years experience in lead mechanical position.
  • Working knowledge of preventive and predictive maintenance, condition monitoring and with the application of computerized maintenance management systems.
  • Familiarity with the theory and practice of rotating equipment and vibration analysis.
  • Experience with the operation and maintenance of gas turbine driven generators, diesel engines, multi-stage centrifugal pumps and compressors, HVAC systems, hydraulic systems and associated auxiliary equipment.
  • Proficient in English both written and verbal.
Salary: Competitive
Working location: Onshore - Vung Tau then moving to offshore work in Q3 - 2020
Application Deadline: 10th November 2019
Applicable to Vietnamese employees only
Send your resume to pvtransofs-recruitment@pvtrans.com or contact us at +84 254 357 6669 - Ext: 201
0
